Just drove home with my new 21 SE and noticed a scratch on the black plastic above the wheel well. It doesn't seem deep when I touch it. My question is, is there anything I can do to fix this short of getting a new black panel?? Land vehicle Tire Car Vehicle Grille
You can fix if, but it may not be perfect.
A product like Back to Black should diminish its appearance to where you can’t really see it, but you’ll have to reapply it later.
A more aggressive fix, which is also riskier, is to use a heat gun or a hair dryer (if it’s hot enough), and gently heat it up to where just the very top layer melts a bit and solidifies again, which will make the plastic dark again. Go slow and be careful if you go with this option, and move the heat around. There are YouTube videos with instructions. I’ve done this with my rear bumper and it worked well.
Thanks sir, I'll try the first option to see how that works first then go from there.
Just drove home with my new 21 SE and noticed a scratch on the black plastic above the wheel well. It doesn't seem deep when I touch it. My question is, is there anything I can do to fix this short of getting a new black panel?? View attachment 148930
Stop texting your ex. :p
Seriously, though, Back to Black.
2019 Honda Pilot Touring AWD
Did you just buy it?
Take it back to the dealership they will most likely replace it at no charge.
I did, I sent a text to my salesman. He's gonna see what they can do. I'm not getting my hopes up so I'll be buying the back to black just in case.
