2012 Honda Pilot
Not sure where it is coming from exactly. I did jack up he car and all the joints looked fine to me. Only issue I saw was cracked open boots where the that small straight bar comes down from the sway bar. At 95,000 miles. VCM is disabled. 2012
Most likely struts. But inspect all your bushings for any that have torn through.
The sway bar links are a good place to start. Remove them and see if the noise goes away.
Reactions: weiss27md
And, if it's similar to first generation Pilots, the noise you describe is front sway bar bushings, but you can't really eyeball they're out of round on the inside until they're replaced. Inexpensive parts, though.
2004 pilot front stabilizer links and bushings
2012 Honda Pilot
Thanks guys. This problem was fixed by replacing the front sway bar links. Took about 30 minutes.
Glad you solved it!
And thanks for sharing the follow-up! Always good to get feedback on actual results.
