1 - 11 of 11 Posts
I have a 2007 4WD Pilot EXL with 157K miles. I'm going to be towing a trailer next summer from Texas to California to move my daughter home from college. I'm planning to add a transmission and power steering coolers before that trip, but since I will likely have the front bumper off the car I'm also wondering if it would be a good time to replace the radiator at the same time.
To that end I'm wondering what is a reasonable expecteed lifespan of a Pilot radiator? Any experiences/opinions about doing this work at the same time as the tranny and PS coolers are welcome too.
The 2005MY Pilots were the ones with an usually high percentage of radiator failures.
A new Denso radiator would cost ~$150.
Given that you'll already be doing much of the required disassembly work, the relatively low added cost to proactively replace the radiator (and hoses - and possibly the thermostat, too) simultaneously would seem to be worthwhile.
Agreed. Perhaps not critical for a 2007, but it's cheap insurance and even easier since you'll be in there.
140743
More Information for DENSO 2213226
5% Discount Code: 3AE5CBE8F18A03
Expires: November 12, 2020
Pilot 2022 SE AWD; Pilot 2007 LX AWD
I have 2007 LX 4WD. Radiator developed very slow leak (bottom, driver side) 2016-2017. At that time car had not more than 100K miles. Replaced it with Denso in 2018.
If you are still with the original radiator, I would replace it.
08 EX-L, 07 LX
Replace it, perfect time to add coolers.. not sure PS cooler is necessary beyond what the car already has (extra long metal line to increase surface area).
If the vehicle has issue with corrosion or rust, it's good maintanance to replace the radiator. Here in Texas, it's not as common of a problem.
It's not neccesary to equip the power steering system with an additional cooler, but there is no harm in doing so. Again, rust and corrosion could be an issue depending on the vehicles history. I'd inspect the power steering lines an OE cooler to see if it needs replacing.
Super Moderator
Here’s a pic of my ‘04 [email protected] that was silently failing yet never caused any issues. Having the front bumper off will make the replacement much easier. Upgrading with relatively inexpensive auxiliary PS and trans coolers since everything is wide open. Inspect your metal lines as I’ve had to replace my rusty crusty metal PS and trans lines in my quest for many more trouble free years of Piloting.
Looks like you might be driving in an area with salted roads? I live in Southern California so it is pretty dry which keeps corrosion to a minimum.
Super Moderator
Yup the annual salt/brine baths each winter season. That's a plus for you in CA but sometimes the metal corrosion can occur from the inside out. For example this can happen to the PS or PB lines if fluids are not replaced periodically.
1 - 11 of 11 Posts
