1 - 10 of 10 Posts
Greetings,
My left front blinker, 06 Pilot, stopped working after driving through a storm on Sunday. The bulb was bad, so I replaced it. It still isn't working. When I put the hazards on it still does not work. Would that be a relay switch issue? Or did something get damaged in the rain like a wire or harness? Thanks for your help.
put a test lead on the socket make sure you have power ..if not then you know where to start ..check the fuses you have a set on each side of the cab one in the kick panel on passenger and one up in the dash ..two in the engine compartment .
Thank you. I fixed it.
What was the solution?
Great, and don't forget to replace the blinker fluid from time to time to keep it working smoothly. :)
1 - 10 of 10 Posts
