2008 pilot bought high -low beams Installed but only low beam works changed polarity no go put old bulbs in they work what could cause (other than wrong bulb sent to me ????
What kind did you get?
I've pointed out in the past that the Owner's Manual (at least for a 2006) has it backwards. I've attached the Service Manual section that has it right.
I purchased Carifax brand on internet LED low an high beam bulbs, seems Like high beam bulb won’t plug in all the way for connection. I jumper wired bulbs to battery they light. Are both low an high connectors the same
