1 - 20 of 27 Posts
Found a bit of a surprise today. Lately I've been smelling coolant on the outside of the Pilot once it warms up. Tonight I decided to have a peak under the hood. It appears the coolant (water) passage gasket, as Honda calls it, is leaking where it connects to the block :28:. I've been monitoring the coolant level, and it hasn't been dropping by visual inspection, but obviously I'm loosing some coolant. I've attached some pictures.
I think I'll tackle this job myself. If anyone has any input on what to look out for, it would be much appreciated.
Overall Bummer.
Had the same problem with my 05 Pilot this past summer. You will need two gaskets (front and back). Most likely, the front one is leaking. However, once you take apart the passage from the block, the back one will also come off and you don't want reuse the old gasket. Clean the surface very well (you may need to scrap off the old gasket and dry coolant residues). I had to do twice as after first quick chang, it was still leaking although much less.
Not a difficult job after all. Good luck!
Discussion Starter #3
Thanks for the input MinMet.
My coolant is almost due for a flush anyway (I have 180K kms), but I thought I'd do it along with the timing belt and water pump at 200K kms. Oh well, good to know its not that difficult of a job.
@dustino8 - did you ever resolve this issue? I smell the unmistakable sweet smell of antifreeze when the engine warms up, and i checked the coolant passage gasket, and there are no signs of a leak there. no leaks from radiator, never any coolant on the ground...
just wondering if your coolant passage gasket repair fixed the issue, or if you're still smelling antifreeze.
Discussion Starter #5
I started the job one day, and it was taking longer than anticipated, so I stopped and buttoned everything back up as I had a previous commitment that wouldn't allow me to finish (and the wife needed the Pilot the next day). I know the new gasket will solve the issue, as its very obvious from where its leaking.
You may have a very small leak that you can't see yet around the coolant passage, because as you know it is difficult to see in that area. I smelled antifreeze for quite a while before anything dripped down below.
dustino8,
I just did this very same repair last Saturday. I would recommend replacing the water passage o-ring at the same time (item #18 in the diagram above). That water passage tube is simply pressed into the back of the passage you are removing. Once all the bolts were off and hoses removed, I had to give it a good wiggle and pull to get it to release. Personally, I also changed out the spring-hose clamps that I removed for the ones that are screw tightened. You can never be too sure how well they will hold/seal once they are removed.
The repair manual told me to remove the battery and the intake tube that connects the TB to the filter housing. I left the battery in place, but scraped the "s" out of my arms. It was a good 4hrs to complete.
Hit me up if you have any specific questions.
Eric.
Discussion Starter #7
dustino8,
Eric.
Thanks for the tips. I ordered the o-ring with the gaskets.
water passage gasket replacement and o rings
This seems to be a very common problem with the 03-05 pilots. As a newbie to owning one of these, my pilot also suffers from this exact issue. As money is really tight these days, I want to tackle this job myself. Has anyone done this job and have step by step procedures they could post? Any assistance would be much appreciated. This is by far the best forum for the pilot I have found.
somebody recently looked pretty deeply into this (perhaps checking the reports to nhtsa or ?) and determined that a majority of the issues reported were coming from the northern, ie, salted-during-winter states (including canada?).
sure, some of the northern folk here may not have experienced it yet, and, i am very ocd about my vehicles, but this one poster's findings set my mind at ease for the time being about my southern-owned car, but, nonetheless, i will replace my radiator in the next few months...
Thanks for pipe O-Ring tip.
I'm about to replace the gaskets on the Water Passage Unit on my 2004 Pilot
as the front gasket is leaking (very slowly).
I have some questions you guys may be able to answer:
1) Does anyone know if there is any sealant required on these gaskets?
2) How many bolts are there securing the water passage unit?
I see 3 on the repair manual diagram but I'm guessing there must be at least 4.
4) Is it necessary to remove the EGR and sensors (that is remove hoses only) ?
I'm hoping there will be room to rotate the unit, for cleaning purposes,
without necessarily removing the EGR and sensors.
Thanks.
dustino8,
Eric.
Is 11 the crossover pipe? They told me the my cross over pipe is leaking. Wonder where it is?
Eric,
Did you remove the intake manifold? how did you get to the O ring that is on the water pump or passenger side? Helm Manual suggests you remove the intake manifold. This will require quite a few more gaskets etc. Let me know. Thank you
I'm in the process of doing this and I cannot get the coolant passage out! It's loose so I don't think there are any other bolts in place. The only hose I see connected is to the connecting pipe. I've wiggled and pulled but it will simply not come out! Any suggestions on what I'm doing wrong?
Okay so I got the thing off but now I'm not sure if it's back on! I tried pushing it on by hand but no luck. So I slowly tightened the bolts and nuts, alternating sides as I went along to try to seat it. There still seems to be a small gap though. Is that normal?
I figured out what was wrong. While installing the water passage, the connecting tube slipped down, out of the opening on the water passage. As I tightened the nuts and bolts for the water passage, it smashed the lower part of the flange on the connecting tube. This basically allowed water to just flow right out the bottom of the connecting tube since it was no longer seated in the opening. I got a replacement tube and installed it and everything is back to normal. The only thing I forgot to do was re-install the ground cable bolt. DOH! Now I have to take everything back apart to get to the water passage to install that but at least the leak is finally fixed. One thing I will note...the gasket for the rear portion of the water passage is revised from the original version. I was nervous about installing it because the hole is larger and the shape is somewhat different but everywhere I read about it said it was the correct gasket because the older one was superseded. So if you're changing out gaskets and notice one looks a little different, that's why.
Are you talking about the tube i circled? Was it easy to get into the other side? Did you remove the intake to do it or were you able to push it through easily?
133441
1 - 20 of 27 Posts
