Hello all, so last night my car had some problems, the past week or so the brake light on the dash had been flashing and all of a sudden the VSA light would come on, last night I was driving then all of a sudden it seems like I couldn't go forward, I pulled over and the car seems to be leaking radiator fluid? The csr is still on but will no go forward just revs up in all gears.
Discussion Starter #2
Update, it's transmission fluid, battery is dead now. Battery never had an issue before last replaced 5/29/2015
You don't say which year you have, but if the radiator fails internally coolant and ATF mix with bad results.
If your brake light inside the car came on, check brake fluid levels. Low fluid likely due to worn brake pads.
