I bought the new KYB Strut-Plus and there are no instructions and none of the Youtube videos cover this.
The Strut mount upper spring plate has an arrow stamped into it and the mount with the three studs has "FR" I am assuming Front Right and one of the studs has a green dot beside it.
What is the green dot indicating...and how do I make sure I install these in the correct orientation?
Anybody got the torque specs for:
1. Strut mount nuts (3) =
2. Two huge 22mm bolts from strut to steering knuckle =
3. Stablizer links =
4. Brake line retainer =
and would you use blue loctite or no?
1. Strut mount nuts (3) = 43ft-lb
2. Two huge 22mm bolts from strut to steering knuckle = 116ft-lb
3. Stabilizer links = I prefer tight
4. Brake line retainer = I prefer tight
