Pilot 2019 has kick-open
Did anybody try to install kick-open from 2019 on the 2018 model?
Yes you can do it, not with the sensor kits, cargadets has one for $109, it doesn't work and would not recommend. I do recommend to get a momentary switch and tap into the trunk handle release wires (remove interior panel on the trunk) and tap into the two wires and run it under the spare tire into the trailer hitch and add a momentary switch to the hitch cover, use spade connectors to connect so you can remove it when you tow.
