41 - 53 of 53 Posts
· Registered
05 EX-L
The front one. Yes the one I installed is a brand new one
Is it possible to test voltage with one of these tools View attachment 166538
All you need is a digital multimeter and alligator clips. All you're checking for is voltage, and verifying the motor works when 12 volts is applied. First remove the wire harness and attach your DMM leads to the wire harness and check that you are receiving a 12 volt signal. If you are, you can try and apply 12 volts directly from the battery to the blower motor. If it doesn't turn on, it's the motor, if it does turn on, and you are getting 12 volts, check and make sure the wiring harness is clicking tight, and none of the wires are loose. Try moving the harness while attached to make sure you are getting good contact. Try while the fan is outside of the housing as well to make sure it isn't jamming against something.
If you are not getting 12 volt signal, it could be a short, an open, or relay, could also be something wrong with the climate control unit. You can role out a short by checking continuity between ground and positive on your DMM. If no continuity, could be an open (cut wire). Check continuity between ground wire and ground chassis make sure it is still grounded.
Sorry, I don't know where the blower motor relay resistor is on this unit, but I believe it is close to the blower motor. Maybe even on the other end of the wiring. Screwed into the housing. Could have gone bad.
· Registered
Discussion Starter · #47 ·
As always, bro, thanks again for your helpful advice that I will definitely put into action ASAP
· Registered
Discussion Starter · #48 ·
[/QUOTE so do you feel like that tool from the picture I showed on post number would work for something like that if I just had to do it today until I can get a multi reader type gadget
· Registered
A multimeter (they can be had for quite cheap now) is definitely a good investment. I can just about promise you this wouldn't be the last time you'd use it.
41 - 53 of 53 Posts
