Has anyone used kerosene as a engine flush and if so how did it do?
Before I used the Cyclo Motor Flush @260K+ miles the V-Tec was sluggish and would not kick in at times.I’d be content with using a good quality full synthetic oil with a quality oil filter, making sure to change the oil on time or sooner and use top tier 87 octane gasoline. If the engine is running badly replace the parts needed to make it run right plus the possible need for a valve adjustment.
I don’t want to be negative on the subject of the use of engine flush products. I don’t doubt that they work. Having bought old vehicles with neglected engines, what I wrote above has brought them back to good health over time. I especially learned my lesson on avoiding fancy oils (extended performance) that claim you can go longer between oil changes. By my experience, these oils needed topping off between oil changes and possibly more susceptible to thermal breakdown. Old oil seems to go places it shouldn’t be. I am back to changing my oil every 5k diligently. My oil loss is barely measurable now. Regular Full Synthetic Pensoil (black lablel) and Quaker State (gold label) are my go to oils for their higher Noack ratings. I thank @xGS for this one.Before I used the Cyclo Motor Flush @260K+ miles the V-Tec was sluggish and would not kick in at times.
I had stuck my fingers in through the oil fill opening and could feel the thick buildup of sludge.
After the first flush there was a noticable difference in the V-Tec response.
I'm using Valvoline Advanced 5W20, with a Purolator One (10K) filter. I now change oil every other MM notification.
After 6K miles the oil is not as dark as the conventional oil was at 3K miles, but still goes black after the flush and checking through the oil fill opening shows an improvement. I can't complain it only uses about 1/2 quart in 6K miles.
BTW I was with the original owners this past weekend, and Chad told me they never had the TB/WP replaced, so it had 260K+ on the originals when I got it.
This motor was sludged to the point that the drain back holes in the heads were all but plugged.I don’t want to be negative on the subject of the use of engine flush products. I don’t doubt that they work. Having bought old vehicles with neglected engines, what I wrote above has brought them back to good health over time. I especially learned my lesson on avoiding fancy oils (extended performance) that claim you can go longer between oil changes. By my experience, these oils needed topping off between oil changes and possibly more susceptible to thermal breakdown. Old oil seems to go places it shouldn’t be. I am back to changing my oil every 5k diligently. My oil loss is barely measurable now. Regular Full Synthetic Pensoil (black lablel) and Quaker State (gold label) are my go to oils for their higher Noack ratings. I thank @xGS for this one.
What oil filter do you guys like?
Which vehicle is that for? Will use on Honda, Nissan, Hyundaiwww.piloteers.org
I think I've finally got caught up to the sludge. The metal parts I can see now only show a light brown discoloration that you can see the metal through, as does the drain back hole that you can see through the oil fill opening. I couldn't even tell there was a drain back hole there before, so I'm pretty sure most of them were just as plugged. Oil now goes in as fast as I can pour it.Lol, I see now what you mean now. Mobil 1 claims it helps with sludge. If you are getting sludge you really need to replace the PCV valve, switch to a good synthetic oil, change oil every 6 months regardless of miles, and address seal leaks. That way it doesn't keep coming back.
I was seeing a lot of sludge on the outside of the engine and I thought that would do the trick but it seems like most people are saying don’t do an engine flush because it’s a waste of money or it’ll create a bigger problemoh I like the sound of dynamic. almost anything sold in the auto parts store could be used as a "flush"
there's probably at least a dozen specific products sold for this purpose, whether or not they actually do anything meaningful is another debate. what are you trying to solve or accomplish by "flushing" the engine?
Yeah I’m leaning more towards just doing a couple of regular oil changes and see if that will help. Thanks to you and everyone for their replies I definitely really really appreciate them! Ever since I installed a new thermostat it’s been idling up and down from around 1000 RPM to around 1500 RPM I’m thinking it’s where I had to remove the breather tube. What do you think the problem could be?I don’t want to be negative on the subject of the use of engine flush products. I don’t doubt that they work. Having bought old vehicles with neglected engines, what I wrote above has brought them back to good health over time. I especially learned my lesson on avoiding fancy oils (extended performance) that claim you can go longer between oil changes. By my experience, these oils needed topping off between oil changes and possibly more susceptible to thermal breakdown. Old oil seems to go places it shouldn’t be. I am back to changing my oil every 5k diligently. My oil loss is barely measurable now. Regular Full Synthetic Pensoil (black lablel) and Quaker State (gold label) are my go to oils for their higher Noack ratings. I thank @xGS for this one.
Yeah definitely sounds good. If a couple of oil n filter changes doesn’t help I will definitely try that brand thanks so much for your replyBefore I used the Cyclo Motor Flush @260K+ miles the V-Tec was sluggish and would not kick in at times.
Did you wipe any dusty grime from around the throttle plate? If so, It may need a cleaning on the backside too and idle relearn procedure. A throttle gasket would be needed.Ever since I installed a new thermostat it’s been idling up and down from around 1000 RPM to around 1500 RPM I’m thinking it’s where I had to remove the breather tube. What do you think the problem could be?
