1 - 1 of 1 Posts
I wasn’t aware of this problem until some indicator lights came on and wanted to pass on the info. While getting gas, my hubby left the car running (which we always used to do) and two indicator lights came on at the same time: the check engine light and the VSA light. In the manual, it states that those lights together will sometimes come on when fueling while the car is on. In my case, it was pure coincidence. I went to Honda to diagnose the issue and it turns out it was a piston ring failure. Honda has extended the warranty to 8 years and unlimited mileage because they are aware it’s a problem for many Pilots. So if you have those two lights on together and you’re within the years/mileage, go to Honda and get the $2400 repair done under warranty!
1 - 1 of 1 Posts
