SUMMARY POST 2: BUILD SHEET AND BUDGET
From Post #7 (page 1), Post #49 (page 3), and Post #73 (page 4) here are the "bare essentials"-
BLOCK - eBay:
Used long block with 96k miles, complete from oil pan to throttle body, some minor damage to harness (that's okay, we're swapping over the 3.5L harness). $1300+$200 shipping & $80 tax
PLUGS - ngk.com:
6x NGK 93175 LKR7DIX-11S Iridium IX Plugs, $50 shipped
TIMING COMPONENTS, GASKETS, SEALS, O-RINGS - HondaPartsConnection.com:
14520-RCA-A01 | Tensioner, Timing Belt Auto | $125.93 | 1 | $125.93 |
14550-RCA-A01 | Idler, Timing Belt (Koyo Seiko) | $46.46 | 1 | $46.46 |
14551-RCA-A01 | Bolt, Timing Belt Idler | $6.01 | 1 | $6.01 |
14510-RCA-A01 | Adjuster, Timing Belt | $101.49 | 1 | $101.49 |
14513-RCA-A01 | Bolt, Timing Belt Adjuster | $7.62 | 1 | $7.62 |
14530-P13-000 | Collar, Auto Adjuster | $26.29 | 1 | $26.29 |
90441-PK4-000 Washer, Sealing (24MM) 1 $1.90
94109-20000 Washer, Drain Plug (20MM) 3 $2.49
15400-PLM-A02 Filter, Oil (Honeywell) 1 $5.69
19222-R70-A11 Gasket, Water Pump (Magna Powertrain) 1 $4.59 (I am reusing the water pump, it was new 5k miles ago)
91214-RKG-003 Oil Seal (80X98X8) (Nok) 1 $16.84 (rear crank seal)
91212-5MR-A01 Oil Seal (41X56X7) (Nok) 1 $7.44 (front crank seal)
91213-RKG-003 Oil Seal (39X53X8) (Nok) 2 $14.62 (cam seals)
91307-RTA-005 O-Ring (Denso) 1 $2.38 (on water passage assy)
91314-PH7-003 O-Ring (31.2X4.1) (Nok) 2 $5.04 (water passage pipe)
19411-P8A-A03 Gasket, Front Water Passage (Nippon Leakless) 1 $4.42
18715-PB2-000 Gasket, Egr Valve (Ishino Gasket) 1 $8.45
19301-P8E-A10 Thermostat Assembly w/ gasket (Nippon Thermostat) 1 $45.79 (also changed when I did timing belt 5k miles ago... could probably reuse but I'm being lazy)
19412-P8A-A02 Gasket, Rear Water Passage (Nippon Leakless) 1 $2.38
08200-9014 Fluid (Hgo-1), One Quart $13.99
Valve cover gasket set & liquid gasket: $60 shipped
OEM ZDX airbox-to-TB elbow and 100mm clamp: $60 shipped
MORE FLUIDS - eBay:
4 quarts DW-1 ATF $40 shipped
Power steering pump kit (2 pints fluid & 2 o-rings) $20 shipped
6 quarts Royal Purple 5W20 full synthetic $70 shipped (I don't run this oil continuously, but have used it as a "cleanout" oil with good success in the past on swapped-in used blocks)
3 gallons Long Life Type 2 coolant $70 shipped
Total of $1580 + $50 + $450 + $120 + $200 = $2400
From Post #14 (page 1) and a correction from Post #53 (page 3) here are the "upgrades"-
SKU | Product | Quantity | Total |
GAT.T329RB | Gates Racing Performance Timing Belt, Honda J-series V6 (Single Exhaust Port Gen-2), T329RB | 1 | $ |
UNO.TS6121 | Unorthodox Racing Billet Tensioner Pulley, J-Series Honda V6 (Gen 2 single-port heads), TS6121 | 1 | $ |
UNO.CU6141| | Unorthodox Racing Underdrive Crank Pulley w/ Belt Option, Honda V6 J-Series J30/J32/J35/J37 (w/ single exhaust port heads), CU6141
Add a Belt
1 - Bando Drive Belt, 2002-06 Honda Accord, w/ UR Underdrive Pulley, 6PK2080 | 1 | $ |
KNN.33-2309| | K&N Performance OE Drop-In Replacement Air Filter, 2009-15 Honda Pilot, 33-2309 | 1 | $ |
RV6.JP_PIT-1215|2389 | RV6 Performance Long Tube J-Pipe, 2012-15 Honda Pilot | 1 | $ |
RV6.HFPC_PIT-1215|G2|2389 | RV6 Performance GEN2 HFPCs (High Flow Precats) Kit, 2012-15 Honda Pilot | 1 | $ |
P2R.P392.2P145 | P2R Intake Manifold Spacer, Gen 2/2.5 Honda J30/J32/J35/J37 (w/ Single Exhaust Port Head & Port Injection), P392
Options: |
Add thermal gasket: | Yes, 2x P2R P145 |
| 1 | $ |
P2R.P326.2P149 | P2R Throttle Body Spacer, Silver, Honda V6 J35Y4/5/6 J37A4/5 (SH-AWD TL/ZDX/TLX/RLX/Ody/Pilot/Ridgeline), P326
Options: |
Add P2R Gasket?: | Yes, add 2 P149 |
| 1 | $ |
P2R.P321 | P2R CNC Ported Lower Intake Manifold Runners, Honda J Series V6, P321
| 1 | $ |
Subtotal: | ~$2250 |
Insurance: | $ |
Standard Shipping (Ground): | $ |
Total: | ~$2300 |
From Post #33 (page 2), some optional add-ons. I ended up forgetting about the rodent tape (keeping my fingers crossed, I guess!) and instead of installing the load resistors I just kept everything plugged into the original solenoids and zip-tied them to the new block. (I'm leaving these out of the totals below)
3x 15 ohm, 25W load resistors from Amazon.com - $11
2 rolls of OEM Honda "Rodent Tape" - $80 (I saw some horror stories online about mice thinking Honda wiring is delicious, so as long as I've got the harness out, now's the time for some cheap insurance!)
From Post #64 (page 4) - an "if you don't have it already" item:
Silicone vacuum / coolant hoses of various diameters - $40 (I'm leaving this out of the totals below)
Assuming you'd like to take advantage of the J37A4's VTEC, you're going to need the AEM F/IC 6 piggyback ECU. They're getting tough to find, but usually run around $350 - $450. We'll take $400 as an average.
GRAND TOTAL:
$2400 for the block and "bare essentials"
$2300 for upgrades (to include upgraded timing belt)
$400 for AEM F/IC 6
$5,100 in parts, plus whatever the cost of labor will be for you depending on how much, if any, you plan to do yourself.
