Bought my Pilot when it was warm and carefully set the air pressure to 36# in all tires.
It's now 59 degrees here and when I checked the pressure this morning it read 30# in all tires - probably the difference is 90 degrees outside temp vs 59 degrees.
Just thought I'd remind everyone that it's time your fall/winter tire maintenance.
JJ
36??? Holy cow, dude!!! You must like a rough ride!!!
Discussion Starter #3
Not really - Tires have a 32 psi minimum and a 44 psi max rating - I chose 36 to stay in the middle - have a good ride - and get good gas mileage.
JJ
I run my Michelins with 35-36 and the ride is fine.
I concur. 35# on Michelin has better ride than OEM Dueller at same psi.
Before the Michelin swaps, I had set the Dueller at 32# and noticed uneven wear at the edges after 4500 miles.
