1 - 2 of 2 Posts
so been reading some old threads here and from what i understand you gotta install hondahack first and then you can install autokit and use the carlinkit dongle?
I'm scared it will screw up my car and then it won't even start!
In case I screw something up, is it possible to factory reset the headunit like you would with any other android device?
I did this. Everything went fairly easy.
There are always ways you can brick the headunit but everything will be OK if you will be following instructions.
As a benefit you can install Netflix to entertain your kids.
1 - 2 of 2 Posts
