I first noticed my parking lights were not flashing when the remote was pressed. Then I discovered the tail lights are not on when the lights are either. In addition, the instrument cluster does not light up when the lights are on. Anybody experience any electrical issues like this.
I checked all the fuses and could not find any blown.
Thanks,
Larry
Saliv8, have you had any accessory installs done recently?
Illiniguy asked my first question. Even if you haven't, a quick check of the fuses still sounds in order.
Chris
Discussion Starter #4
No installs and as stated before all fuses are intact. I am taking it in tomorrow...
when you disarm the alarm...
Does your instrument light comes on and off and then on and off?
Mine does. Is it supposed to do that?
The instrament pannel lights are suppied from the "Park/Marker Light" line. So they will flash with the remote lock function, as it flashes the park lights.
Discussion Starter #7
I only checked 2 of the 3 fuse panels... I didn't know there was one on the passenger side as well!
