1 - 2 of 2 Posts
Our 2010 Pilot decided to die yesterday. The gauges went dark, the center odometer is completely out. Go to start the car, it wants to start, runs for a second and shuts off. I can not put in neutral or change gears. Code reader is throwing "U0155 - Lost communication with Instrument Panel Cluster (IPC) control module.
I assume this means I need a new instrument panel. I've checked battery, cleaned terminals, checked fuses, etc. Everything checks out fine.
What else could it be? Is there a fuse I am missing?
1 - 2 of 2 Posts
