I have all of the proper equipment (not quite sure what an "extension" is however) and just looking for tips, suggestions from those have installed them on their own.
Thanks.
Here's a tip...don't let the sidesteps fall on your head as you install them-
Hope that bit of advise helps!!!
If I remember correctly from my install, you will need an extension (I used a 6") for your ratchet wrench to more easily reach in between the brackets to tighten all the bolts.
It's a very simple install. I put it together loose and then went back and tightened it all up. It probably took an hour to an hour and a half in the dark with no light.
Helpful hint
I installed the bolts toward the center of the vehicle first and then used that as a pivot point to raise the side step and install the oitside bolts prior to tightening the bolts. I did mine unassisted - my wife would not help even though it'd her Pilot...
Note: What's hers is hers and what's mine is hers!
:21: :21: :21: :21: :21: :21: :21:
Discussion Starter #5
Thanks Twinkie and Older than dirt .
Nice to know that there are still some people on this forum that like to offer some useful advice.....and not just take up space.
I'll give the side steps a go this weekend.
*cheers*
Good luck!
May the force be with you...
