I just noticed that the insides of both my rear tires are worn considerably more than any other part of the tires. Have any of you had this issue? Is there rear camber adjustments on a 2016 Pilot Touring model? Will a wheel alignment correct the issue? Could my shocks be bad? On both sides?
I could rotate my tires but then it would just ruin the tires I rotate to the back.
I haven’t been towing any nor is there any extra weight on the back. I can’t seem to figure out what could cause both sides to do this at the same time.
Thanks.
Thanks.
