The price for the Honda Pilot Fog Lights w/ Lower Trim on Honda Acura World is $299 whereas the price for the Honda Pilot Lower Trim (which I assume is w/o fog-lights) cost $349. Why is the latter more expensive and you're getting less?
1) Lower Trim = Lower trim
2) Fog Lights w/lower trim = Fog lights FOR USE WITH lower trim installed
3) Fog Lights w/o lower trim = Fog lights FOR USE WITHOUT lower trim installed
Hope this helps
If you need a fog lights along with lower trim , it will be 299 + 349 . Looks like honda is having different setup for foglights with lower trim and with out a lower trim .
In another thread, discussing fog lights and lower trim, N_Jay also had this info:
N_Jay said:
If the dealer is doing the trim, then have them do the lights.
Just don't allow them to double charge you for the labor, as the removal and replacement of the bumper needs to be done only once.
If you are doing the trim, then do the lights yourself. It is easy. Read some of the articles posed on them.
I thought the info about double charging labor was worth repeating.
Discussion Starter #5
Awesome!! Thanks for the replies. This definitely removes the fog!!
