1 - 20 of 31 Posts
I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot. I'm an Idiot.
There was some tar stuck on the driver's side door of my Pilot. I was having a hard time taking it out. So I took another rag that was a bit coarse. Rubbed hard and got the tar out. Yeah!... Uh oh, stupid me, tar came out alrighty, but it looks like I scratched up the clearcoat as well. Look at the area from an angle and you will notice a dull spot where the clear coat was taken off.
Before I do anymore damage, what do you guys think about Meguirs Scratch X. Supposedly this stuff will help eliminate scratches and swirls.
:D just buy a fine rubbing compound and wipe it with a water moistened rag until you cannot see it anymore. no big deal. and do not start banging your head on the wall yet!
I've had good luck with the Kit Scratch Out for removing swirls/blemishes.
My theory is to start with the least abrasive stuff first, and work your way up. I'd start with a wax or wax/cleaner like Meguires. Go easy and use a soft cloth. This may take out enough of the surface scratches that you won't notice it anymore. If this doesn't work, try a polish with light abrasives. If that doesn't work, then go very lightly with a polishing compound.
Good luck. From what you've described, I think you'll be able to take care of it pretty easily.
if you insist so hard we will agree:2: :2: :2: :2: :2:
I have used this product with good results, it is on the strong side of waxes/cleaners but it is still a wax/cleaner not a compound, so I would start with it but if the scratches are bad they might not take them out and you might need to move on to a light compound. Good luck and let us know how the scratch X works for you or if you need to use something else.
wow this scratch x stuff works pretty good!
Before when you look at the spot from an angle you could see an obvious dull spot surrounded by scratches. It was an eye sore on a bright sunny day. The car would sparkle except for the one spot.
Well this morning I applied two coats of scratch x and the dull spot is gone. The scratches for the most part are gone as well. Looking at the area it's not as obvious anymore. You have to really squint to find the spot now.
I should have taken pics before and after. would have been a good Meguirs promotion.
So coming back to my original problem, what are best means to removing tough stains such as tar without ruining the clearcoat/paint of the car?
I agree with the above, but want to add, that taking out scratches without putting in swirles is as much about method as it is about product.
Remember, the best body and detail shops don't use any special or magic stuff. Just good old 3M polish (of the corect grade) and lots of practice.
WD 40 works great on tar. Spray some on a cloth, rub on spot, spot disappears.
:D I saw the dealer in michigan apply some spray to remove some bird droppings without harming the clear coat. might be a good bet to ask them.
Does WD 40 break down pine sap as well as tar? If not, what would you suggest?
WD 40
WD 40 is great. If you get oil etc on cloth seats a little WD 40 on a cloth takes it off. Same thing for smudges on the headliner or carpet etc.
Hmm, seems they make bug and tar remover for this purpose.
Why buy a specialized product when what you have around the house does as good a job or better? B&T remover's probably nothing more than WD40 in a brighter package, and 300% markup, anyway.
Autopia
I've been lurking on http://www.autopia.org for about a month. If you have any question about how to clean/polish/wax your car, boat, furniture, kitchen, or cat check it out (just kidding about the cat, but the rest are discussed there). BEWARE, these guys are serious! If you have the slightest clean gene, I'd stay away. It's adictive, much like this board.
... plus saving a trip to the store isn't too bad. :)
By the way, jay, thanks for that sap removal URL!
Well then just use Windex. It fixes anything! :2: :2:
I guess I believe that most of the time there is a good reason why products are designed for a specific purpose.
They may do other things, but either not as well or with side effects.
WD-40 is a decent solvent, but it is also a lubricant.
So now you have stripped any wax off the finish and left an oily coating making re-waxing difficult.
Bug and tar remover is typicaly mineral spirits (solvent that eveporates clean) mixed with a wax to restore the surface.
It may also have a small amount of polish in it to act as a mild abrasive.
You would be better just using paint thinner (strait mineral spirits) and rewaxing, than using WD-40
Not sure if you are joking are not N_Jay, but it does a great job of pulling up soiled spots on carpets... if you don't have something like Tuff Stuff lying around. I prefer Gunk (spray can) glass cleaner over Windex due to Windex's habit of streaking.
Good point about the effects WD40 on wax...
By the way, do you use duct tape on anything other than ducts ? :)
1 - 20 of 31 Posts
