flyalteon said:
Thanks Larry... I must have been asleep at the wheel for a few days... Its for the transmission solenoid.
Is this the TSB you're looking for:
http://www.in.honda.com/Rjanisis/pubs/SB/a04-021.PDF
The number you gave looks more like the date the TSB was issued and not the TSB number itself. I'm guessing you're looking for a TSB that was issued on September 16, 2004.
I went to alldata.com and they list these TSBs:
Automotive Recall and Technical Service Bulletin Titles for 2004 Honda Truck Pilot V6-3.5L.
TSB Number & Issue Date TSB Title
04-021 APR 05 Recall - Automatic Transmission Second Gear Inspection
04-047 AUG 04 Recall - Incorrect Tire Certification Label
06-085 MAY 08 Campaign - Vehicle Warranty Mileage Extension
06-009 FEB 08 Campaign - OPDS Unit Warranty Extension
04-059 OCT 04 Campaign - Fuse Box Label Replacement
08-088 NOV 08 Audio System - Poor Reception Diagnostics Revision
99-082 OCT 08 Navigation System - Warr. Exchange/Non-Warr. Repair
05-032 OCT 08 Navigation System - DVD Information And Inspection
04-040 AUG 08 Drivetrain - Noise/Judder From Vehicle Rear When Turning
04-009 JUL 08 BULLETIN CANCELLATION NOTIFICATION
89-022 MAY 08 A/T - Cooler Flushing Equipment Information
88-023 MAR 08 Electrical - Battery Testing and Replacement
04-063 JAN 08 Fuel System - Accelerator Pedal Popping/Sticking/Binding
04-003 JAN 08 Body - Tailgate Spoiler Foam Strip Hangs Down
07-030 OCT 07 A/C - Refrigerant Leak Detection
06-068 OCT 07 Steering - Vehicle Pulls/Drifts to the Left/Right
00-049 JUL 07 Antitheft System - Immobilizer System (Type 2)
01-023 JUN 07 Computers/Controls - Updating Control Units/Modules
07-012 FEB 07 Music Link(R) - System Information/Diagnostics
99-030 FEB 07 Body - Recommended Sealers/Repair materials
07-001 FEB 07 Suspension - Front End Rattles On Bumps
07-008 FEB 07 Body - Unibody Repair Guidelines
99-062 JAN 07 Paint - Industrial Fallout Paint Damage
06-082 DEC 06 Tires - Tubless Tire Repair Information
99-018 NOV 06 Tools - Required Special Tools And Equipment
06-081 NOV 06 Electrical - Horn Honks By Itself On Bumps
00-088 OCT 06 Disc Brake System - Brake Disc Refinishing Guidelines
06-030 JUN 06 Engine - Idle Vibration/Harsh Shifting
01-077 APR 06 Ignition/Locks - Cutting Sidewinder-Type Keys
SN040905 SEP 05 A/T Or Engine Noise At 4,200 RPM
05-030 JUL 05 Body - Accessory Hood Air Deflector Cracks
SN050600-011 JUN 05 A/C - Heater Blows Cold Air, A/C Blows Warm Air
05-016 MAY 05 Restraints - Child Seat Anchor Locating Button Missing
SN050508 MAY 05 Exhaust System - Catalytic Converter Noise
SN050506 MAY 05 Wind Noise - Simple Way To Replicate
SN050407 APR 05 A/T - Do Not Remove Torque Converter From Mainshaft
SN050418 APR 05 Body - Plastic Body Clip Removal Tips
SN050408 APR 05 Driveline - Hissing Between 30 and 50 MPH
SN050314 MAR 05 A/T - Fixing Banjo Bolt Leaks
SN050317 MAR 05 A/T - Oil Jet Hoses Now Available
SN050316 MAR 05 Engine Controls - Clearing DTC's
SN050313 MAR 05 Restraint System - Seat Belt Tongue Stopper Position
SN050311 MAR 05 Windshield Wipers - Blade Care & Replacement
SN050202 FEB 05 A/T - Avoiding Fluid Contamination
SN050215 FEB 05 Audio System - Never Play CD's With Adhesive Labels
SN050203 FEB 05 Engine Controls - DTC P0171 Set
SN050206 FEB 05 Engine Controls - DTC P0172
SN050210 FEB 05 Navigation System - Replacing Lost or Damaged DVD's
SN050109 JAN 05 Engine - Oil Recommendation GF-4 Standard
99-070 DEC 04 Navigation System - Setup and Operation
SN041208 DEC 04 Buzzing Or Clicking On Hard Acceleration
SN041206 DEC 04 Dashboard Switch Not Lit,? Replace Bulb, Not Switch
SN041202 DEC 04 Engine Conrtols - Got DTC P0128? Replace PCM
SN041204 DEC 04 Fuel Filler Cap Adapter Available For Testing Emissions
SN041006 OCT 04 A/T - Removing Stubborn ATF Filler Bolt
SN041010 OCT 04 A/T - Replenishing ATF On Vehicles With A/T Oil Jet Kits
SN040902 SEP 04 DTC P1457 - Check For a Twisted EVAP Purge Hose
SN040915 SEP 04 Driver's Air Bag - Replace Torx® Bolts Properly
SN040910 SEP 04 Wind Noise At The Hood Air Deflector Seal
SN040813 AUG 04 Thump When Accelerating Or Braking
SN040805 AUG 04 Wheel Bearing Noise After A/T Replacement
04-041 JUL 04 LIghts - Tailight Reflector is Loose or Distorted
02-052 JUL 04 Restraints - Occupant Detection Initialization
SN040703 JUL 04 A/C - Poor Cooling During Hard Acceleration
SN040606 JUN 04 Oil Pressure - Low Indicator Blinks On Start-up
SN040417 APR 04 A/T - Don't Test Drive With The MIL Or D Indicator On
SN040414 APR 04 Roof Rack - Wind Noise
04-019 MAR 04 Brakes - Rear Brake Clunk Sound
04-018 MAR 04 Navigation System - Personal Addresses Can't Be Viewed
04-010 MAR 04 Suspension - Clicking Noise From Right Rear
SN040310 MAR 04 ABS - Grunts When Doing A Self-Check
SN040313 MAR 04 SRS - DTC 15-1, No.7 Fuse Blows, Rear Wiper Inop
SN040315 MAR 04 Water Leak From Door. Check Rain Protector
98-011 FEB 04 Keyless Entry - Remote Transmitter Information
SN040215 FEB 04 ABS DTC 51 Or 53 - Diagnostic Tip
SN040115 JAN 04 Engine Cranks But Doesn't Start, Immobile Light Blinks
SN040111 JAN 04 Engine Oil Recommendations
SN031208 DEC 03 A/T - Leak From Cooler Line Banjo Bolt
SN031204 DEC 03 Starts & Stalls - New Immobilizer Logic Used
SN031106 NOV 03 Air Fresheners - Bad News For Paint Or Plastic
SN031107 NOV 03 Blower (Heater) Motor Gets Hot and Blows A Fuse
03-065 SEP 03 Paint - 2004 Paint Codes
SN030905 SEP 03 A/T Whine - Test Drive Tip
SN030915 SEP 03 Suspension - Drifting & Pulling At Highway Speeds
SN030813 AUG 03 Interior & Exterior Trim - Tool To Make Removal A Snap
SN030502 MAY 03 Clearing DTCs & Setting ECM/PCM With The HDS
96-012 JUL 00 A/C - System Performance Testing
It's possible there are others but the only real way I know about to get them is for your local Honda dealer to give you the TSB number or for you to use the URL pattern in the first post in this tread and try them sequentially.
Good luck!
Larry.
