Where'd you get two bottles? One bottle fills the reservoir. There is no pump drain unless you pull a line. You could do this multiple times over a few drives to do a near complete change out.So two 12 oz bottles for the reservoir and what's sucked out of the pump?
+1 This weekend I changed the ATF, engine oil, bled the brakes, tire rotation, antifreze change, and changed the power steering fluid on my 2005 Honda Accord. What I used was exactly what Rocky mentioned. I took our turkey baster, added a 1/4 inch clear tube and then commensed to suctioning out the power steering fluid from the reservoir. I used one Prestone synthetic power steering fluid bottle. The fluid I removed was put into the oil container I dropped off at Autozone.I'm embarrassed to say that I don't think I have actually changed the power steering fluid ever. At least I can't find any record of doing it until today.
The 12oz bottles of fluid are very cheap from the dealer. A Baster makes a great tool for removing the fluid out of the reservoir. Grab an empty can of soda which is also 12oz and fill it with the fluid you pull from the reservoir. Fill that up and you know you know that you have enough fluid on hand to refill.
What shocked me is that while the fresh fluid was clear, the old fluid looked more like dirty ATF.
Going to lower a q tip into the reservoir in a few days to see what color the fluid is now. Then decide whether to repeat the exercise.
The factory fill has kept the pump lubricated and the seals pliable enough not to leak for 12 years and 200K miles, sure you can probably use anything, . . . maybe . . . .Maybe a silly question, but I've been told to only use Honda fluid in the power steering (and it wasn't by a dealer). Is this really important or can I use any stuff I buy in there? It's a 2003 with 200K miles on it, so not real concerned about it overall...
Well that's not good - I guess I'll have to get it taken care of sooner rather then later.Yes replace that line.
The fluid is flammable.
No toasted Pilots allowed !
