I need to check the ATF level after doing a 4x drain and flush. But I have an S-VCM installed which blocks the signal to turn the fan on based on coolant temperature. I'd disconnect it to check the ATF level, but it's a PITA to get to the connectors, and knowing my luck I'd break something anyway.
I have to put the car on ramps to get close to level because my driveway and street are sloped, so it's a production just to check the transmission fluid. But if I knew that the fan usually turns on at 2 minutes or 5 minutes or 10 minutes of idle it would be really helpful. I had it idle for 13 minutes, and I even kept it at 3000 RPM a few times trying to get the fan to kick on until I realized the S-VCM was interfering (confirmed via email with seller).
FWIW, I took out a gallon of ATF and put in a little more than a gallon because after 13 minutes the fluid was just at the lower dot. The very first D&F, I only got 3.7ish quarts out. The following 3 times, it was all about a gallon. I have no idea how that works.
I don't know what kind of magic they have in this transmission that makes the reading only meaningful after the fan comes on once (but not twice) and only for 60-90 seconds after you shut the engine off. Seems like a bug and not a feature.
