1 - 1 of 1 Posts
Info here works for 2014 as well. So I haven't seen anyone do this method, and I personally think it is much, much easier than the more-popular "map light microphone" method outlined in this post.
ANC wiring from the Service Manual:
145979
So, I will be cutting the white microphone wires at C701, which is much more accessible than the mic locations.
C701 is behind the left A pillar:
145980
How to remove the A pillar trim:
145981
C701 harness diagram:
145982
So for me, just have to cut white wires 23 and 24. I believe without moonroof (left) it would be 19 and 7.
Used a flush cutters (one of my favorite tools!) and a razor to cut away the e tape and plastic shell around the wiring and pull it off, exposing ~2" of wire. I couldn't see exactly where 23 and 24 came out of the harness, but they are the only 2 white wires other than the ones on the ends (1 and 16), so it was easy to find those, and snip them:
145983
Wrapped the ends in e tape for good measure, and done!
If you ever wanted to re-enable, could just strip and solder a jumper, or use T taps with a jumper.
1 - 1 of 1 Posts
