I guess I just don't understand why you would omit such a grievous lurching like that...even it only happens occasionally.
I guess I just don't understand why you would omit such a grievous lurching like that...even it only happens occasionally.Occasionally, especially when I forget to write down all my questions and topics. I just didn't think it was worth chasing this stuff with the dealer, I'm sure I've been put in the "difficult customer" group by now. It did get me a free "accidental" oil change once though...my car was in the greeting area and the service manager saw it sitting there for longer than he thought acceptable, and ordered someone to take it back and start the service without giving them any work order. So the tech dropped the oil, and then when he was given the paperwork and saw it wasn't called for, they told me not to be surprised to see the maintenance minder reset. So that free oil change is the only thing Honda has offered me for my problem Pilot...oh well.
Mileage?I don’t mean to being up quite and old post but my 12 Pilot does this too! On flat surfaces only from park to drive it like sputters. Did you find anything out?
85,200 all maintenance is up todate even timing belt and no light.Mileage?
All maintenance up to date?
Engine light off/on?
Assuming it’s “not” the engine trying to stall and is transmission related.., I do have some concern when we’re talking about an 11 year old vehicle with these low miles, averaging only 8k miles per year. In other words, this Pilot have not reached 90k miles still has about 45% of the original factory DW-1 ATF still left in the transmission, with the 3rd scheduled ATF drain and fill coming up in 4.8k miles. That could be next year. Quite simply, the transmission fluid is likely old, if it is how I’ve stated. Please correct me if my calculations are wrong.85,200 all maintenance is up todate even timing belt and no light.
I’ve done 3 drain and fills on it. With Honda fluid. It only does this every so often and only from park to drive never park to reverse or neutral to reverseAssuming it’s “not” the engine trying to stall and is transmission related.., I do have some concern when we’re talking about an 11 year old vehicle with these low miles, averaging only 8k miles per year. In other words, this Pilot have not reached 90k miles still has about 45% of the original factory DW-1 ATF still left in the transmission, with the 3rd scheduled ATF drain and fill coming up in 4.8k miles. That could be next year. Quite simply, the transmission fluid is likely old, if it is how I’ve stated. Please correct me if my calculations are wrong.
If so, I’d immediately plan on 2 drain and fills of the ATF using full synthetic Valvoline MaxLife ATF. Do this on level ground (no ramps), let the beset for at least one hour, jack the drivers side rear tire, open drain plug and let drain to a slow drip. This should allow for a 3.8 quart refresh of the 9 quart system. After driving the vehicle a few miles, allowing the engine and transmission to warm to operating temperature, do a 2nd, as the first. With 2 3.8qt D&Fs your transmission will have about 60% fresh fluid. After driving 500-1000 miles (no rule), I’d do a 3rd bringing it up over 80% new full synthetic ATF.
How long ago was the last D&F?I’ve done 3 drain and fills on it. With Honda fluid. It only does this every so often and only from park to drive never park to reverse or neutral to reverse
No more than 15,000 miles agoHow long ago was the last D&F?
Valvoline MaxLife has solved many people’s transmission issues. I would be at Walmart picking me up a couple of 1 gallon jugs.No more than 15,000 miles ago
I have a transmission warranty and I’m nervous if I did change the fluid to Valvoline it would mess up the warranty. I mean do trans fluids look different?Valvoline MaxLife has solved many people’s transmission issues. I would be at Walmart picking me up a couple of 1 gallon jugs.
I’m not one who pays for warranties, but I don’t know of any case of anyone being denied a warranty for using VML. Does your warranty specify using DW-1 only? How can an 11 year old vehicle be under warranty?I have a transmission warranty and I’m nervous if I did change the fluid to Valvoline it would mess up the warranty. I mean do trans fluids look different?
Just that things can’t be out of OEM spec and I just got the car a year ago and bought a 3 year engine and trans warranty…I’m not one who pays for warranties, but I don’t know of any case of anyone being denied a warranty for using VML. Does your warranty specify using DW-1 only? How can an 11 year old vehicle be under warranty?
Do you use Honda oil and filter?Just that things can’t be out of OEM spec and I just got the car a year ago and bought a 3 year engine and trans warranty…
