1 - 10 of 10 Posts
Heat turned up to high/max. Vent on driver's side door blows cool, vent on right of steering wheel blows warm, all other vents blow hot/seem like they are working as they should. Any ideas as to why? I did have a timing belt service done this fall. Ideas? Thanks
Have you heard any clicking under the dash? The blend door actuator can go bad.
The other thing it can be is a plugged up heater core.
See post #6 with pics and video on a DIY fix.
Once you have verified the drivers blend door is working correctly, then you need to flush the heater core. Needs to be a clr flush, don't waste your time with anything else.
What seems odd to me is, at the CLR website it says “do not use in automotive radiator”. A heater core is a small radiator.🤷‍♂️
Probably not good to add to coolant and leave in there for extended time. It is the Honda approved chemical for external pumping through the core.
I can't imagine even thinking about leaving that stuff in for an extended period of time. With all the little nooks/crannies in a heater core, I find it hard to believe being able to 100% flush that stuff out. Maybe that's why CLR specifically says "do not use in". Wonder if Honda read the "do not use in" warning at the CLR website?🤷‍♂️
It's probably approved by Honda because they know it's possible that stuff can eventually eat a hole in the heater core and that will be some major cha-ching for a Honda dealership to replace the heater core.
I hook a hose up to the core, and let it run 15 min in each direction as the last step of flushing. I have done lots of them, starting in 2014, so far no issues.
CLR is an awsome product. It only eats away at rust and corrosion. It's diluted with water. So by a through rinse, you shouldn't have any fears of it continuing to eat away at your heater core.
I'm not saying......CLR is saying. YMMV. 🤷‍♂️
No clicks or unusual noises
1 - 10 of 10 Posts
