1 - 11 of 11 Posts
06 exl with 227k. Flushed heater core and hot air came back in dash. Rear heat is cool at best. Looked online and don’t see my issue anywhere. Any thoughts?
Did you purge/burp the air out of the cooling system after the flush? Perhaps there is an air pocket trapped in the system.
How is the airflow from the rear fan? Have you cleaned the rear fan screen? (Pull open panel in center console at drivers ankles, fan has an intake screen like a dryer filter that is usually linted up). Order some drive-through french fries, drop one between drivers seat and center console, mark french fry locationt, measure forward 8 inches, remove plastice panel and you will find the fan.
Hahaha.... making me hungry now. Airflow is good. You happen to know if the rear air has a heater core?
Cleaned the fryer basket while I was looking for the elusive fries. Dang! I really am hungry for fries now.
After chasing said fries between seat and dash I burped if that counts. Lol. No, I made sure to park and let run on an incline. It’s lunchtime, I’m sorry.
I’m hungry too.
There is definitely a separate heater core (and A/C evaporator core as well) under the center console.
If burping and vacuuming bring you no joy, next try swapping out the thermal resistor. It's to the right of the blower in the first picture above.
Rear blower Transistor Fix
Amazon.com: PartsSquare Rear A/C Heater Blower Motor Resistor Compatible with Acura Mdx 2001 2002 2003 2004 2005 2006 Blower Resistor Replacement for Honda Pilot 03-08 HVAC Blower Regulator 4P1493 RU364: Automotive
1 - 11 of 11 Posts
