Ok, I could use a little advice.
A couple of weeks ago, my 2012 V6 Crosstour with 267k miles popped a P0304 Code, misfire cylinder 4. Checked fuel trims, Bank 2 fuel trims were way negative (lean) while Bank 1 was normal near -0+. So everything I read, figured I needed an injector. I decided to replace all the injectors while I was in there. After I replaced the injectors (Genuine Honda). It was improved, but I knew it still wasn't right. Today the scanner showed not only P0304 but P0300. Again, fuel trims for Bank 1 are normal, Bank 2 👎.
Where would you go from here.
