I am installing running boards on my 2013 Honda Pilot EX and I found that the mounting holes on the pilot are not threaded.
Can I just tap them to add threads, or is there an insert required?
All the factory bracket holes in the tub are already threaded except for the rear one on each side. A new set of Genuine Honda running boards comes with a Nutsert-style threaded insert for those two holes, which you can install using a hack bolt-and-nut-and-two-washers if you don't have the tool. Some have glued a nut onto a washer and slid it into the rail from a nearby larger hole. The bolt size is 8-1.25 IIRC, and you can probably substitute a 5/16" Nutsert in a pinch if you don't have access to the correct 8mm size.
Search the forum some and you'll find more on this. More than a few folks were blindsided by needing that insert put in. You could sometimes talk a dealer service guy into doing it while the car was in for something else. With the correct tool it takes less than a minute per insert to place and set them.
I know the 6 holes on each side are supposed to be threaded, but they were not! I bought a tapping tool and put threads in the holes and now they are able to take the 8mm bolts. I had a problem with the "rivnut" installation, but I bought a pkg of them, along with a piece of sheet metal and I will do a bit of practicing first.
Wondering if yours were perhaps victims of undercoating or rustproofing? This is the first mention I've heard of the weld-in inserts not being threaded.
Now you worry me! There were no weld-in inserts. Just holes in the metal. The holes were thick enough to be tapped and threaded, but NO welded-in inserts.
This is interesting... I just installed Westin running boards on our '15. There were 5 holes on each side that had threads, but given the vehicles age I had to chase them all to clean the threads. One hole on each side needed a nut to be installed, Westin supplied a "wire nut" instead of a rivnut... basically a nut with a 12" thin rod welded onto it that you fish through the hole in front... I expected it to be a huge PITA to tighten down and position properly but it went pretty smooth.
In my case, there were 2 holes (1 on each side) that were two thin to tap, so a rivet nut had to be installed.
When I say the holes were threaded, I mean there was either a nut welded on top of the sheet metal or something else, there was close to 1/2" of usable threads in those holes. This was not a hole in sheet metal that is tapped... if you did that I'd be concerned with the strength of those threads with people standing on the running boards.
I will have to talk to the local Honda Dealer and ask what happened with my unthreaded
holes. There are no welded nuts, or inserts. I just tapped the holes. And I am concerned
with the strength, which is why I first posted. But these holes are designated for running
boards, so why are they not threaded? Makes no sense. Maybe I can get an answer from Honda.
At this poing all I could do is drill the holes out to 7/16" and use rivet nuts.
