Those of you that have done this, how hard was it to do? I looked at the instructions and it looks pretty straight forward. The only "tricky" part seems to be getting the access panel off without scratching or breaking anything.
Also, is the rubber weatherstripping that you remove glued on, or does it slide right off???
BTW, I TT a service rep at Honda and he said that the coolers are recommended only if you are hauling 2500 lbs. or more--
