I am noticing a very large difference in the RPM vs speedometer reading between my 03 and new 05 Pilots.
The 03 Pilot at 2000 RPM in 5th gear indicates 73 MPH. The 05 Pilot at 2000 RPM indicates only 62 MPH. Same road, same conditions. Both vehicles have the exact same size OEM wheels and tires and I believe the gearing is the same also. The difference in not due to speedometer error which is what some might offer as an explanation. I have timed both vehicles against mile markers and get the same speed as indicated on the speedometers.
1. Does anybody know if the lockup torque convertor is somehow temporarily disabled (computer controlled) while the 05 is under a certain mileage? (like a break in precaution)
2. If it is computer controlled break in precaution, when should the computer allow the lockup to work (at what mileage?)
3. What is the 5th gear ratio for an 03 and 05 Pilot? I think the gearing is the same so the RPM vs road speed should be very similar.
The 05 Pilot does not drop in RPM like I see on my 03 Pilot at the same road speed. If the lockup torque convertor is not going into the lockup mode, this would explain why the RPM is so different between the 2 models.
I have contacted the dealer but no reply yet. Can anyone here explain the speed difference at the same RPM? Thanks.
