So I just noticed today my reverse lights aren’t turning off even after the car is off also my dash camera stays on as if I am still backing up. What part could this be? I can’t find it anywhere on the internet.
How is your dashcam wired? That's where I'd start my investigation.
If no wiring modifications have been made recently in the rear of your Pilot (or accidents or corrosion), perhaps pull out the Nav unit and check if all the connections are good, disconnecting them and reconnecting them.
I'm also wondering if the NAV unit has a "reset" function?
If that doesn't do it, you may have to hunt down the continuity in your wiring with a multimeter, not a fun job.
Or the outlier might be the transmission range sensor.
That's all I can think of for now.
