1 - 17 of 17 Posts
The cover that goes over my center console broke and has left a huge gap where it was supposed to retract. My phone slid through it and is now stuck in there! How can I remove it?!?! It's a 2013 pilot
135021
You also might want to try pulling off the the big, long side panel on the side of your console to access what fell down behind it. If it's anything like a 2006, it's just clips holding it in place, so the easiest is the grab it from the edge way up near your gas pedal and pull it out toward you, working your way back to where the driver's seat is. It's basically how you access the rear blower motor, which you may as well vacuum clean while you're at it.
2005 Pilot LX
You can also pull the similar panel on the passenger side.
Watch "2009-2015 Honda Pilot Stuck Console Lid / Assembly / Shutter won't open" on YouTube
I'm assuming you got your cellphone out? That was 18 hours ago.
Reactions: plplplpl
2005 Pilot LX
O Cellphone, Cellphone, wherefore art thou Cellphone?
@plplplpl It’s sorta from Romeo and Juliet. I’m not plagiarizing.?
Reactions: plplplpl
135070
Reactions: plplplpl
2005 Pilot LX
Hopefully OP is okay and figured out how to get to the lost cell phone.
1 - 17 of 17 Posts
