If you have a multimeter you can easily check the state of the charging system. Verify battery voltage is ~12.6Vdc after the Pilot has been turned off for a few hours. If lower than ~12.4Vdc I would charge the battery with an external charger before continuing.
After battery has been verified as fully charged, measure voltage across the battery when the Pilot is on but all major loads (A/C, headlights, cabin blowers, etc.) are off, then measure the same when the loads are on. First measurement should be ~14.4Vdc and second measurement should be ~14.2Vdc.
If all that checks out then you can start looking for parasitic draws. There are a couple methods for testing that. Pilot is turned completely off when doing this. Either measure mVdc (millivolts) across each fuse (fuses with highest measurements indicate potential problem circuits) or disconnect battery negative and put meter (in current measuring mode) between battery negative and the battery negative cable. Pull fuses one at a time and look for a significant drop on the meter. Once you’ve identified the problem circuit(s) then the fun part of debugging begins.
