Hello I was wondering if it was possible to take the heater control out of a 2003 EX and install it on a 2005 LX? Would it be able to just connect right up would some modification be needed?
Are the part numbers the same?
On a 2006 anyway, the heater control is dependent on sunlight and temperature sensors on EX and EX-L models. First check if you have these in your 2005 LX.
138617
But I've also attached the HVAC section of the 2003 LX Service Manual which indicates it might indeed have those sensors. Check.
But yes, check if they are both the same part number.
