Hi. Can't believe that I just joined several days ago and I am now posting a MAJOR problem !!! Last night, driving home in a Baltimore rainstorm, I noticed people flashing their headlights my way. Much to my chagrin, I then realized that my headlights were not on--nor could I turn them on !!!! I shut the engine--hoping to recycle the computers. Nothing. This morning, I checked it out again in the daylight---no headlights. My dealer is closed--and the Honda customer care number is unmanned over the weekend. I will bring the car to my dealer tomorrow and repost the final diagnosis.
Also--has anyone ever had their navigation system go dead ?? If you do not activate system in the first minute, you get a black screen--totally normal. However, touching any button should "bring it back to life." My system does not return to life every so often without an engine re-start. Dealer cannot find the reason.
Anybody else getting this problem ???
Thanks----carla.
A major problem?
I would check the fuse first for the headlighs.
As for the NAV, make sure Honda knows about your issue, not just the dealer.
Strange. The left and right headlights have their own relay/fuse circuit. The fuses are number 43 and 45 in the under hood fuse box according to the manual. Just one failing would be very rare and would indicate a short circuit type problem, both of them failing would be really odd. The dealer should be able to find the problem quickly since the lights don't work at all.
Bad ground?
Coincidentally, I had a similar experience this week. Mine affected the right headlamp only, both high and low beams. With the headlights on, there was a faint glow in the right bulb, but it did not cast a beam. The dealer traced it to a bad ground at G-401, which is on the left side of the dash (the switch is on the ground side of the circuit). I haven't analyzed the circuit so I can't explain why only one headlight was affected.
Discussion Starter #5
Hi. Had the car to the dealer on Monday. Yes--there are separate fuses for each headlight--strange--and they were fine. Turned out to be a faulty headlight activator switch--the stalk on the left side of the steering wheel. Dealer said they had never seen that before. Part arrived Tuesday, and now all is well.
Navigation issue still unresolved--Honda USA does not have an answer, either.
Still, the PILOT is the best looking, best value SUV on the market today. Sure, I have read other posts speaking about what the 2004 should have as standard features--and some ideas are great. But then again--will the PILOT remain the great value that it is today?
carla------- sagebrush pearl EX/ NAV
Weird coincidence
I purchased Sylvania Silver Stars back in September. One- (1) of the low beams burned out during Thanksgiving, so I replaced it then. Last night, I turned on my headlights, and both low beams were burned out. The high beams were fine. I had to drive home with my high beams on. Luckily I had my original bulbs at home to replace the Silver Stars. They worked fine on low and high.
I find it odd that 2 bulbs purchased at different times would burn out the low beams at the same time. Not sure if it is the bulbs or short circuit. I talked to my Service Department today & they blamed it on the Silver Stars. They claimed that they are a great product, but they don't last very long. The outside temperature was only 34&#176F, but that may also be a factor with Silver Stars.
I called Sylvania, and they will replace them for me for FREE once I send the bulbs back.
Brighter bulbs, less life!
There is no free lunch.
I had one of my Philips +50% bulbs go out, abut thge other is fine.
These were put in in August I think, but had made 4 all night drives.
Cold weather will cause a bulb to fail a bit earlier than normal, but I do not call 34deg cold.
Well, here in Jawjaw we call 34 degrees cold! It doesn't get much colder down here.
Guess the point was;
If the bulb is about to go, it will go during a turn on, and the colder it is when turned on, the better the chance of it going.
You see a lot of "Pidditles" when we have a 10 Deg morning.:2:
