2021 Pilot Black Edition White Pearl
Does anybody knows what is the LED type for 2021 pilot black edition is it 6000K? ad anyone knows how to change the light bulb? I tinted the headlights so I wanted to change the headlight bulbs to a brighter one maybe like an HID.
I don't think you can change the "bulb" because the BE has tiny LED lights instead of one bulb.
You can try to, but its going to cost you around $1600. Honda full LED fixtures are sealed, meaning if you have a bulb burn out you take it to the dealer and they replace the entire fixture.
141259
That's what I figured it's not just one bulb, I spent about half an hour figuring out. Thank you guys for the helpful response. I was able to change my dome light bulb to LED thought which looks great. Thanks again guys!
I'm putting led turn signal lights all around, the headlights are fine. If anything do a light tint cover.
Sent from my P30 Pro using Tapatalk
It's kinda late for me to put a lighter tint. I've already put a dark tint on all the exterior light but, I did it the same time I put PPF and ceramic coating. The LED signal lights is great idea I have that thought but I was focus on the headlights first, but now I know it's hard to change the headlights so I'm going to do upgrade on the signal lights.
Thankfully LED bulbs don't burn out super quickly? This seems like something BMW or Mercedes would do.
Yeah that's is what I've learned that LED has longer life span compare to HID
Yeah the led turn signal lights make a big difference compare to the stock ones.
