Done by the dealership ..heavy vibration during Idle..still have the factory coil packs running ..i am thinking of swapping out those coil packs...
sounds like i need to take it back ?
If it is a miss you should see CEL and read a code. Does it run well when in gear and in motion?
Discussion Starter #3
No code at the moment ....Runs well in motion and through the gears just did the differential fluid and trans ... going to check it again when I get home tonight ... only in idle it's rough.. throttle body egr valve all been cleaned / replaced
Does it idle at the correct RPMs? I am suspecting a vacuum leak as the air duct is known to dry up and crack on these cars.
