2008 EX-L AWD, 176,000 Miles
A week or so ago my check engine light came on. I have a mechanic I trust do most of my work these days, so I took it to him to see what the diagnostic computer would find. The Pilot was still running just fine, so I did not know what to expect. He calls with a diagnosis of the engine not running the correct temperature, so the decision was made to replace the thermostat and temperature sensor. Because he was doing that anyway, he removed that section of the intake and cleaned out the carbon build-up and fixed a small leak where it all attached to the heads/block. He got all that back together, took it for a test drive and the check engine light came back on. This time it showed a bad anti-knock sensor, so he replaced that. He took it for a test drive and thought all was good. I picked it up late on Friday and before I was a mile from his shop, the check engine light was on again. I have driven it close to 400 miles since and it runs just fine. Gas mileage is as good as it has ever been for me.
A bunch of years ago a friend had a similar situation. Every time his mechanic fixed one problem a different code would pop up. They ended up realizing that the main computer was going bad. Once they replaced that, he didn't have any more issues. I'm wondering if something like that is possible with my Pilot. Anyone have any thoughts?
Additional info:
Timing belt was replaced at about 147K and my mechanic said he checked the valves then. He also took a peek at the spark plugs then and said they were fine.
While performing this thermostat replacement he discovered that the intake tube was starting to crack, so we put a new one of those on.
Any thoughts would be appreciated! I will be taking it back in a couple days from now, but hoping to have some possible ideas to run past him.
Big Bob
Additional info:
Big Bob
