I just bought a Honda Pilot LX and have driven about 500 miles so far. I live in New York city and as a consequence have to drive a lot on pot-holed roads, both big and small, on both highways and local roads.
The Pilot suspension seems a bit harsh even if driven on small bumps or holes. On some larger bumps there is even a slight tendency to bounce. The Pilot IS VERY smooth on good roads.
Would like to know if anyone else can comment after driving on similar roads. Has anyone had a problem with the suspension so far?
My first suggestion is to check the tire pressure. When these vehicles are shipped to the dealer, the tire pressure is raised for transport.
-Newt:2:
What were you driving?
First check the tire pressure, then check your expectations.
I experience the same problem and I also drive in NYC. My tire pressure is 35. Should I lower it to 32? That’s how it came from the dealer. I think that when it’s cold out, having tire pressure a bit higher might not be a bad idea.
Discussion Starter #5
Thanks, will check the tire pressure. I was driving a 1987 camry sedan, so it should not be too much to ask that the Pilot suspension be better than my old car!
