1 - 20 of 31 Posts
Noticed the light. Kept driving. Everything running fine.
Borrowed my neighbors scan tool.
It had one code- #0154? It says it's and O2 sensor?
Cleared it with the tool.
Drove to and from work yesterday- about 70 miles- no more lights.
I leave swim practice for work this morning- light is back on.
I'll have it read at AutoZone on the way home today.
Probably the same light/code.
I did a search just for that # in the titles- didn't see anything.
What would you do?
My choices are keep driving it.
Read the code- if the same- replace the 02 sensor. However I've read numerous posts about something similar and replacing the 02 sensor didn't fix it.
It's often some other cause- being read as the O2 sensor?
Case in point- about 6 months ago I had many codes, misfires in all cylinders, etc.
It ran fine. I cleared the codes- those never came back. Cost $0!
Unless you suspect air/fuel mixture problems, the code is for the top, front O2 Sensor. Inspect wire, clean connection. Replace it if the code persists.
You did close up your air intake not long ago. The throttle body may could use a good cleaning, front side and back.
Reactions: The Todd
The top, front bank O2 sensor? Thanks
I haven't even looked at it yet. I'll get the codes read again by AZ on the way home today.
See which codes their scanner comes up with? Hopefully only one and the same one.
Reactions: Nail Grease
Correct, the easiest O2 sensor to replace. 👍
Reactions: The Todd
That was my thought as well when replacing both O2 sensors on my son’s Highlander. I’m grateful that the one under the engine in a cramped space came out easily while the upper one created a set back. I carefully re-tapped the hole and got some threads back. Be sure to use sparingly either the supplied anti-seize or copper version. The backup plan was to weld a bung onto the manifold.
Gas Auto part Wood Plumbing Automotive wheel system
Jaw Art Snout Artifact Sculpture
For best results use OEM or NGK
Ah man, the easiest to replace, but the most expensive!
148150
Avoid Bosch like the plauge.
That was my thought as well when replacing both O2 sensors on my son’s Highlander. I’m grateful that the one under the engine in a cramped space came out easily while the upper one created a set back. I carefully re-tapped the hole and got some threads back. Be sure to use sparingly either the supplied anti-seize or copper version. The backup plan was to weld a bung onto the manifold. View attachment 148146 View attachment 148147
That's NOT what mine looks like! I thought it was the top O2 sensor, right up front - behind the cooling fans. I looked at it yesterday. Sprayed it w/ carb cleaner, etc.
NG- That ways NTK?
A local AutoZone has one in stock- front upper 02 sensor- NGK-$115.
However, if this is shipped free and quick, maybe I'll get that one?
AND- Ya'll didnt even mention that (after reading an older post) you have to take the whole plug bracket off the front head- to get the plug off the bracket- to get the plug apart!
148181
OK, an NTK? States actual OEM part would be $6 shipping, and would take a week.
I don't mind spending $15-20 more and getting NGK from Auto zone- a local return too if needed.
** Any tricks for getting that plug/wire off? I've read you have to take it off the bracket first?
Luckily it still runs smooth and well. I hate driving with a check engine light though LOL
NG, or others, I looked for a good picture of this Bank 2 Sensor 1 , but couldn't get a good one to post.
It's NOT what the one that was posted though.
Discussion Starter · #12 ·
Oh, now I realize this was on a Toy Yoda you were working on? Thanks.
Discussion Starter · #13 ·
NTK is Original Equipment.
I didn't see NGK on RockAuto.
OK, then maybe when I checked AZ locally via phone call, when I said NGK, they saw the NTK- which was at least $40 more than the Bosch they also have LOL.
NGK
NTK
Denso
I would choose any of these according to price and availability.
There is a release on the wire harness that holds it to the metal bracket. This can break off easily if not careful (old and brittle). I don't recall having to remove it to unclip the O2 sensor from it.
Reactions: The Todd
Bosch O2 sensors
148182
Reactions: aggrex
2008 Pilot EX-L
Just put black tape over the light. It is all emission related. Does not effect drivability . Just ignore it.
Discussion Starter · #20 ·
Do you have an O2 sensor socket?
No, and with a wrench there is little to no room to turn it too! I'll cut the wires if I have too LOL
Yeah/Naw- Not going that route. IIRC- it can affect the injectors and the a/f ratio?
Or if you want to go total barbaric just cut the wires and use a deep socket but there will be no turning back 😂
'Total Barbarian', that's me LOL
1 - 20 of 31 Posts
