Hey guys, getting the fuel cap warning light. Put in a new cap, cleaned everything up. Light comes and goes over the next 1k miles.
Didn't see any codes with the scanner.
Whats the order of operations beyond this to troubleshoot the problem?
Before you spend any change on this issue do one simple thing. Crank that thing all the way around 2 or 3 times to make sure it gets good and tight. Had the same issue with a 2013 Touring, took it to the dealer and that was the advise given to try first. Problem solved, never had the issue again. Apparently Honda's fuel cap needs to be well seated. One of two clicks won't do it.
