Does anyone know which wire is the turn signal and which wire is the parking light going to the front combo socket?
I want to replace the amber incandescent bulb with an LED and do not like making permanent alterations. I have a plug-n-play solution that needs some modification. It has a resistor pre-wired for both the turn signal and the parking light, causing the fuse to blow for the external lights when the parking lights are turned on.
A wiring diagram or a picture pointing to the wire would be very helpful.
Thank you
I had to determine this on my old Silverado so I could tap the parking lights for my fog light "turn on" wire to the relay. I determined this by unplugging the bulb and putting my tester on the various pins in the harness while my wife turned the parking lights on and off.
Right-front turn signal conductor is PINK
Left-Front turn signal conductor is BLUE
Parking light conductors both sides are GRAY
Ground wires both sides are BLACK
Reactions: dogs_ruleme
