Front Passenger Door Removal
2298 Views 87 Replies 5 Participants Last post by  Frodo
2005 Pilot EX, Daughter dinged the door and starting to rust. I found a door at used car lot for 2004 Pilot
1) Apprears that door for 2004 and 2005 identical so can be interchangeable, anyone know for sure or where to check
2) I cannot find any videos on how to remove entire door ?
Any help highly appreciated
21 - 40 of 88 Posts
Drive around (safely) and see if it stays off.
What would you use to reset it if it doesn't? What kind of code scanner do your have?
Regular App based OBD scanner, Honda implied as this was a US vehicle they dont have ability to read SRS codes?
I use this, the cheapest code scanner that reads Honda specific codes, does SRS and more. I still have Torque Pro on my phone with Bluetooth dongle, but since I got the Foxwell NT630 Plus, I use it all the time and it's paid for itself several times over.
Reactions: 1
Got a door from Kenny u Pull in Cornwall(y), will post pre and post install. Orders the OBD reader from Aliexpress and will see what codes show up. Tried cleaning with compressor and electrical contact cleaner, no luck. Will see if Honda gives me parts and let's me install myself
Reactions: 1
I think you will be happy with the Foxwell. I don't have one, but my scanner will read SRS codes, not sure what Honda is talking about. Looking forward to pics. For the front door, you also have to remove the front fender to get at some bolts.
  • Helpful
Reactions: 3
Brought Door home, can get away by not removing front panel. Will install May24 weekend in Canada. Waiting for scanner to checkout Airbags
Reactions: 1
Honda cant seem to locate Seatbelt latch, I have hunted high and low on ebay, anyone know where else I can find it also where can i locate the Honda OEM part numbers as that makes it easier to find on the web. Ebay has alot chinese knock offs I dont trust
I have one, for sure.
I can pay for it and shipping, let me know
Send me a pic of what you need. I'll be home Friday, and should be able to get it in the mail Monday.
  • Helpful
Reactions: 1
2
See attached pic, it's for the driver side, ping me at [email protected] ans i can send you address and arrange funding
Sleeve Automotive design Grey Collar Automotive tire
Tints and shades Motor vehicle Font Bumper Rectangle
See less See more
4
Door replaced , cutting the harness conduit, had some wires cut inadvertently, soldered back:cool:, thanks to all for your your tips and advise. It was more challenging than I anticipated due to the wiring harness and connectors were not the easiest to remove.
Automotive tire Plant Motor vehicle Automotive design Fender
Automotive tire Hood Automotive lighting Motor vehicle Vehicle
Car Tire Vehicle Wheel Automotive tire
Wheel Tire Automotive lighting Vehicle Automotive tire
See less See more
Reactions: 1
Dang, wrong color. Yours is dark grey, and mine is light grey.
Car Automotive design Vehicle Steering part Material property
See less See more
  • Haha
Reactions: 1
I know why I said to remove the front panel. I replaced my hinges too.
Reactions: 1
Am not fussed about color after 240 000 miles, if you can still ship would be appreciated and will cover costs
Reactions: 1
I forgot to say j/k about the color. Am heading out to pull it now, will send a pic when it's out.
  • Helpful
Reactions: 1
Thx
  • Haha
Reactions: 1
It's out, and boxed. Will be contacting you about shipping address.
Automotive tire Automotive lighting Vehicle Hood Motor vehicle
See less See more
Reactions: 2
Car Tire Wheel Vehicle Hood
painted stripe:D, window mechanism runs rough but assume this sat out for some years, will take inside panel off and lubricate scissor mechanism
See less See more
Reactions: 3
Question on the Airbag light, still intermittent but will see outcome once I install the belt clip that ImBroke is kindly shipping to me, but once I install do I need to reset the SRS airbag via OBDII tool (still waiting for Aliexprsss delivery for scanner per earlier recommendation). Any thoughts
21 - 40 of 88 Posts
