For those who have done this job before. Question about replacing the front motor mount. I've removed all four base bolts and the one actuator bolt, plus the mount stop and its two nuts. All of the bolts shown in the picture. I'm now trying to jack up the engine from beneath and I end up jacking the whole car up. The motor mount is not separating from the frame mounting point or the bracket (called the actuator) on the engine. Does the bracket/actuator also have to be removed? I was expecting to be able to jack up the engine slightly at this point and just move the mount sideways and eventually out of the way like the repair manual says. Any advice? Thanks in advance.
