My foglight does not lightup and before i take it to the dealer, I just want to confirm this:
Pilot's fog light control is the third button on the lower left panel (Cruise being the first one).
I have an image of me going to honda service and they just push another switch.
Fog lights
The factory wiring requirtes that the low beams be on, and the switch is pressed in.
The light in the switch should come on, and the fogs should light.
If neither comes on I would check the 2A gog light relay fuse under the dash. If the switch lights but the fogs don't, then check the 20A fog light fuse under the bumper.
emc02
i just got my fog lights with trim installed and the dealer told me that for Honda fog lights to work, the headlights have to be on. I'm not sure if you tried that, but it's worth a try.
Discussion Starter #4
swoon said:
emc02
I tried it with both headlight on and off.
Discussion Starter #5
Re: Fog lights
the switch lights but the fog dont. I am not sure on how to look at a fuse. i'll take it back to the dealer.
Low Beams Only
Standard installation fogs will only light with low beams, not high. When foglight dash switch is pushed in, green indicator on switch should light and fog lights should come on when low beams are on. If green indicator lights on switch but not the fogs, agree it appears something's amiss with the installation.
The fogs will work wenever the low beams are on, with or without the ignition on. (When wired acording to Honda)
When you use my modification, then they work with the park lights.
(That includes Park, Low, High, and even when the Parks lights flash during remote lock/unlock)
