2011 Pilot , Had minor damage in front end, after repairs fog lights worked but would not turn off when high beams were turned on. Now they don't come on at all ! Low and high beams work fine but have no fog lights ! Anyone else have this and how did you repair ? Thanks !
Have you looked for damage, bad connections, etc. at the wire harness going to the fog lights?
If there is a fog light relay do you hear it click when the fog lights switch is toggled on and off?
And welcome to the forum.
When the fog lights don't turn off when the high beams are on then confirm the fogs were wired correctly after collision repairs to the low-beam/parking light circuit. If the collision repair was recent they should be able to make the repair.
Thanks ! Wiring looks good. I'll look at relay !
Thanks ! I'll double check wiring and check the relay also !
I ordered 2 Relays because they are $4.50 on Rock Auto. Started checking things today and fount that the fog light fuse was blown ! ! I can't believe my Inspection mechanic didn't check that before getting on me about my fog lights not working ? I replaced the fuse and they work and even shut off when I turn on my high beams ! Easy fix !
