1 - 20 of 279 Posts
JimB823 said:
Ok, I've got this going on. Has anybody had this happen and it not turn out to be the dieing tranny prob?
Lots of people.
It can be as little as a bad sensor or bad connection.
Discussion Starter #3
Well it started on me, out of nowhere the D/drive light started flashing. Took it out of gear to neutral, the nuetral light comes on but the D light is still flashing. Pulled to the curb and shifted into park, the park light comes on but the D light is still flashing. Turned the engine off, let it sit 30 seconds, started it back up and everything is back to normal. Drove 1/2 a mile and it starts flashing again. By that time I'm about a mile form home so I drove on home and called 2 dealers. One says as long as its shifting ok and drives ok, bring it in and they will check the codes and see if there is a code in the computer. The other dealer says with it flashing I shouldn't risk driving it, have it towed to them (which would cost me about 200 bucks because its across town). Said screw it and drove it to the first dealer, which is much closer. They checked the codes and there was nothing. Checked tranny fluid and it was full and the right color. He says as long as it's shifting ok, drive it awhile and see if anythig else happens or the light comes on and stays on, or make an appointment to bring it in (they are booked until next week). Don't want to do yet. It's a certified car. Guess I'll give it a couple days. Oh btw, on the way to the dealer the light didn't blink the entire time. 3/4ths of the way home, it started flashing again
That also happens to me on D but i noticed that my fuel indicator was also flashing so i realized that it was also a warning for me to refuel. So when i did refuel the D stopped blinking. Hope we have the same issue.
Discussion Starter #5
Hmmm, that would be weird. Nothing else is flashing on mine. Drives fine, acts ok except for that blinking light. Don't know, Guess I'll find out when I take it in but they are scheduling next week sometime. Really odd thing is that it started blinking in the same place on the same road both times
Flashing shift indicator
That's not all that's going on with my Pilot....
I have just over 900 miles on my '07, and I am getting the flashing shift indicator as well at the 'check engine' light.
I just picked the car up last week, brand new off the dealer's lot, with just 8 miles on the odometer.
I first got the lights this past Sunday, just after I filled the car with gas. I did not top the tank off, and I drove as I normally would. That day was mixed--highway driving and easy driving around town. The shift indicator flashed after I accelerated onto the highway, and the check engine light came on at the same time. I took it easy driving home, and parked the car. I parked, turned the engine off and removed the key. I then waited a few seconds, and started the car back up...no blinking shift indicator, but still had the check engine light. The check engine light was gone the next morning.
Monday I drove from Raleigh down to Atlanta with no problems--no blinking shift indicator, no check engine light. I stopped once to get gas...no problems. It wasn't until Monday night--I accelerated hard from a dead stop to see if I would have a problem, and sure enough...the same lights.
I filled the car with gas, came back to the house for a while, then got in to drive to work, no lights.
I got in the car to drive home tonight and as soon as I put the car into reverse to back out of a parking space--I got the check engine light. I took it easy driving home, and took off (gently) from a stop light, and I get the blinking shift indicator.
Anyone seeing these problems?? Anyone??
N_jay's response is likely on the money, but suggest posters put the MY of their vehicles in any posts. See if we can spot a trend.
It could be as simple as a bad sensor, or even the cars computers "booting up" incorrectly.
OK--put the car in the shop this morning...
Sat around for about 90 minutes and the service advisor says it looks like the problem is a bad shift range sensor. The tech had a bunch more diagnostic stuff to get through, but in the interim, that's what it looks like.
Honda is overnighting the part, and hopefully, we'll be back on the road tomorrow.
In the meantime, I'm rolling in a Chevy Silverado crew cab rental....yee hah.
Flashing Shift indicator--update
Got a call from the dealership....
The sensor was okay....they did a software swap with the transmission module and the car is being road tested. They're gonna keep it overnight and test it again in the morning (since the lights were sporadic).
It sounds like things should be good.
Service just called!!
They tested things again this morning, even with the computer hooked up to the car.
Everything appears to be fine.
All they did was just re-initialize the software. They drove the car 18 miles and had no problems, so that should do it.:29:
Re: Flashing shift indicator
Kind of amazing that now we have to re-boot our cars to solve problems. And I'm not that old.
Maybe your dealer will upgrade you to Vista Ultimate for free to compensate you for your hassle. ;)
Chris
Flashing Shift Indicator
Okay....I spoke too soon.
Leaving work tonight....put the key in the ignition, started the car, pulled the lever towards me and BAM!!
Got both lights again....this is killing me!!
Well, I'm afraid it's back to the dealer in the morning!! :rolleyes: :3:
Well, I am now on my fourth visit to the dealer!!
They replaced the shift range indicator last Thursday and kept the car overnight to test it on Friday, no problems.
I drove the car to work, drove it home and parked it. Got up early Saturday morning and drove to the airport, parked the car--no problems.
Got the car from the airport Monday morning, drove to work, no problems. Monday night--leaving work--BAM! Check engine/flashing shift indicator. So much for the software re-install/shift range sensor replacement!!
I called the dealer where I got the car from in North Carolina, and their techs are checking around to see if anyone else has run into the same problem. So far, no takers.
I've owned six Volkswagens, a Nissan and two Honda products (a Honda Element and an Acura CL 2.3), and my Pilot is the only one that has given me problems right out of the box. My car only has 1700 miles on it, and I just made the first payment!!!
I've already looked at the North Carolina Lemon Law statute--if this keeps up, I'll be a candidate for it.
Re: Flashing Shift Indicator
I hate intermittent problems.
There is just no way to tell if it is fixed.
We purchased a 2003 Pilot and noticed 2 things immediately: sporadic flashing Drive indicator (not easily reproducable) and SRS light came on (curiously enough right at the dealer during a check-up).
Dealer initially could not locate any codes for the flashing "D" and plead the "cannot replicate" case, but eventually i drove it into the dealership while it was flashing and they diagnosed it as a bad temperate sensor in the transmission and replaced it under extended warranty. No more problems with that. Service rep indicated that this was something of a well known issue...
2 SRS sensors were also replaced to correct that problem.
Now if only i could figure out the latest problem: Why the horn and lights stated flashing for no apparent reason several times i'd be a happy Honda customer. Try getting that one replicated sitting at the dealer!
Hmmm....a bad temperature sensor in the trans caused the shift light?
That would probably make sense in my case, and I'm sure that triggers the check engine light, too.
I'm gonna send an e-mail to my service writer and tell her about it.
Thanks for the info!!
But one other thing--did yours flash while driving? Because mine seems to come on after the car has been sitting, and for whatever reason, only at night.
Discussion Starter #20
Well I started this thread but havent been back because..... I drove it to the dealer and they checked for a computer code and found nothing. He asked if it was driving/shifting strangely and I said no, can't tell a difference. So he said go ahead and drive it and if it happens again or acts strangely then bring it back. So far, nothing. Hasn't come on again and no odd shifting or anything.
But, and this has nothing to do with it, one time I came to a stop and heard a hissing sound that was coming from/near the brake pedal. Take my foot off the brake and it stopped. Put my foot back one the brake and when I pushed hard I'd hear a contant hissing sound like a tire with a decent sized hole that was leaking air. Drove to the next light and stopped and heard nothing. And havent since. I dunno.
1 - 20 of 279 Posts
