2009 Honda Pilot EX-L
This is the second time I've received the Flashing D. I got the code 0976 using a bluetooth OBD II reader. The first time I had it I had Solenoid B replaced. Took care of the problem. Now I have it again and I just had this replaced in September of last year. When I get this my Pilot shuts down and shifts like a bucking bronco. Seen many posts about replacing sensors but I haven't seen one with the code 0976. I just had the timing belt done and my mechanic said the ATF was nasty and to drain and fill soon (Probably first time it's ever been done). I just did that tonight and I still have the flashing D. ATF didn't look bad, but I had what looked like sludge on the drain plug. Just bought this used last year in May. Been reading and learning a lot on here about things I can do myself. Appreciate any suggestions before I take it back to the Service Center.
Speedometer Gauge Auto part Car Vehicle
If there is no conector damage(wire loose, corrosion oil soaked) or short in the wire harness, then valve B is likely faulty again.
If your fluid has never been changed. I would do a 3 time drain, fill drive with MaxLife Full Synthetic ATF. Especially if the old ATF is non synthetic Honda DW-1.
Reactions: Yingy and aggrex
Thanks for the advice. I'll pick up some oil tonight and have it all swapped before I have the solenoid changed. I'll take another look at the wires to, just to make sure.
Also check your connection. Do you have an oil leak? Engine oil can travel down a wire harness and in time foul out a connector. If so, Get a can of CRC Electronic Cleaner and spray clean these connectors inside and out. Wal-Mart has the best price for this.
Did the 3 time drain and fill before I took it in. Got the solenoid changed. Everything covered under warranty. 12 months/12,000 miles. Glad it took care of the problem again, just hope it never comes back.
2004 Pilot EX-L
The sludge on your transmission drain plug was probably metal filings from the breaking down of your transmission innards. There a magnet on the drain plug that collects those filings so they don't keep circulation though the transmission.
